It is currently Wed Aug 13, 2025 12:24 pm
PostPosted: Sun Sep 20, 2015 8:40 pm
How many cut the headblock mortise before installation vs. after closing the box on a non cutaway flat top?
Why?
PostPosted: Sun Sep 20, 2015 9:12 pm
Last Name: Shanklin
City: Windsor
State: ON
I do it after.
Bob
PostPosted: Sun Sep 20, 2015 10:23 pm
Last Name: McDonald
City: Okanagan Centre
State: British Columbia
Zip/Postal Code: V4V2H6
I dont always do things the right way,but, I dado out a piece long enough to give me multiple blocks,cut to length then either cap or fill the bottom.
I have been trying to make up extra pieces whenever it requires a special set up.
Hopefully, one day the bulk of the parts will be roughed out and it won't take me 8 months to complete a project.
PostPosted: Sun Sep 20, 2015 11:56 pm
First name: Danny
Last Name: Vincent
Always after. Takes about 10 or 15 minutes with a very simple jig and a pattern makes router bit. I do use a big router. I've never done it the other way but it would suck if the mortice didn't land right where you wanted after the box was closed.
PostPosted: Mon Sep 21, 2015 5:41 am
First name: Tom
Last Name: West
State: Nova Scotia
I make the block a bit longer then required. Drill holes vertically either side of mortise location to fit two finish nails. Cut off where I want bottom of mortise. Cut mortise in longer section. Glue back together using locating nails. I have not had a problem in over 40 guitars with offset location. Just a bit of care in glue up required.
Tom
PostPosted: Mon Sep 21, 2015 6:02 am
I've done it both ways but you do have to be careful with layout if you cut it first. Now I have a jig so I cut it after.
PostPosted: Mon Sep 21, 2015 9:18 am
Before. I don't like using routers, though I have a nice PC 690. I drill it out with Forstner bits then clean up with a chisel. Quiet that way, though it takes longer.
PostPosted: Mon Sep 21, 2015 9:35 am
Last Name: Miller
City: Wood Dale
State: Illinois
I was taught to make neck block with mortice before gluing to sides. Very touchy gluing in correct place. You have to allow for some adjustment so neck and FB line up afterwards. This approach works with making laminated neck using three similar pieces of flat sawn wood with middle piece being tenon.
Like everything else in making a guitar, the geometry has to be right when everything goes together. I would like to build jig to rout out mortice after closing box. Image
PostPosted: Mon Sep 21, 2015 9:43 am
Last Name: Miller
City: Wood Dale
State: Illinois
This is way I learned to make a three piece neck. ImageImageImage
PostPosted: Mon Sep 21, 2015 1:37 pm
Last Name: Beaver
City: Lake Forest
I cut the mortise and drill for the bolts first. I do have a jig for cutting the mortise after the body is assembled but it it easier for me to do it first.
Joe Beaver
Maker of Sawdust
PostPosted: Mon Sep 21, 2015 5:55 pm
I did it before at first, but now really like doing it after. Easier to line up and with a couple jigs the mortise and tenon fit very nicely and right where you want them. When I did it the Cumpiano way I never liked the way the binding wasn't fully supported behind the mortise.
Kent
Users browsing this forum: doncaparker, Ken Lewis and 17 guests
